Hi All
I tried create a composite field from 2 date fields lets call them Date Created and Date Verified where the logic is
If the Date Verified is more recent than the Date Created then use the Date Verified.
If the Date Verified doesn’t have a value then use the Date Created.
There will always be a Date Created.
Date Verified should be in theory more recent but i would prefer to check that it is
I got the impression that this wasn’t possible so i followed the instructions in
So I Created a New Field to store the pseudo “Composite Field”. Called Newly Registered date.
In Code studio when into references and add references etc.
When I came to write the code i could not work out how to get the values of the attributes and properties of the record.
const caseRecord = mats.record(params.record_id); // Gets the id of the record
but how do you get the other ones?
Also the Date created is a Timestamp so do i convert that to a date.
Any help pointers etc would be appreciated
Kind Regards
Steve W.
