How can I automatically refresh the page after importing data from a spreadsheet on the same page? Currently, If I don’t manually refresh the page, the new data is not shown. I looked in the settings but didn’t find any options related to this.
Thank you in advance for your assistance.
Best regards,
Katerina
Hi Katerina,
In case it’s good enough, there is an “Auto-refresh” setting for the whole page (Basics tab) and for specific widgets (including List). This just allows you to refresh on a regular interval.
If that is not good enough and you are using the main Import widget, I suspect there isn’t a way to do this. Perhaps suggest an Idea to Netcall.
If you are importing from a file in a record, there will be a way to do it with a little Code Studio code. I can try and help further if this is the case. But I suspect it will be quite a bit of work.
Frosse
Netcall Partner
