Hi, Is there a way of reporting, the number of outstanding emails ( i.e. unread) per Queue? I’m sure I’m missing something. thanks
Hi Ian. The simplest way would be on your Dashboards. You could add a Dashboard that uses the Interaction Count Widget that displays Emails waiting and set one up for each Queue.
Or use a Queue Summary Widget and set this to display per Queue and set this only for Email
This would give you live data on each of your Queues.
From a reporting perspective, you could use the Queued vs Completed report. Here is a link to the information on this report from our document portal, which is under the resource tab at the top of the page.
Queued vs Completed
Do let us know if you have any more questions.
Jonathan Redsell
