Reporting on calls rejected due to capacity issues
We have an on premises Liberty Converse 5.1.1 solution with two servers. Each server has 30 inbound SIP channels and we have noticed that on Monday mornings we are saturating these for long periods. During this time, we have no way to track how many calls the system is rejecting so we can forecast how much extra capacity we are likely to need to purchase.
Is this data easily accessible in a report, or manually available elsewhere, or is it simply not logged as it is over capacity?
Many thanks in advance.
EDIT: I should probably state that this is across all Contact Centres, Contact Portal, Voicemail and Call Queues etc. All services are affected when we hit capacity, so we could do with knowing how many calls to each service we are missing.
HI Andy, unfortunately there is no report that shows how many calls missed due to capacity being reached as the system is unable to see the calls coming in. You may be able to see this from a call logger/PBX report but that can depend on the vendors reports they have.
Sorry we couldn’t help on this matter.
