SCCM issues agent software distribution
HI, Anyone here managed to get sccm to deploy the web agent, it is not deleting remnants from the registry or the app folder……….thus failing the attempted install, PowerShell script not doing the job.
Hi @Andyp
Thanks, reaching out. For full details on how to deploy the Agent application you can take a look at the documentation here:
https://docs.netcall.com/docs/liberty-converse/5.14/liberty-converse/technical-information/on-premise-deployments/agent-desktop-app.
If you’re still running into issues after following this, the best next step is to email support@netcall.com so we can help with your specific setup.
Kind Regards,
