Hello,
I am trying to create a way for users to select multiple options as an answer to a question. I have tried setting this up through a Relation Ticklist. Would this be the best way to allow the user to select multiple answers? If so how would it need to be configured for it to work correctly as currently it is just stating no data available.
Many thanks
              Hi @JessEvang ,
It depends on the context in which you want to show multiple selections. Are the selections going to be fixed choices? If so, then using a Choice data type is your best option, then presenting the information however you like (e.g. Tiles presenter)
However, if you want to show choices that are based on record data, thus allowing you to continually add more records to represent choices, then using a relation-type widget is the right option here.  So in your case, using a Relation Ticklist widget would allow to show a ticklist representing the record data. However, you do need to have record data created to represent those options, which is what I think you may be missing.
So for example, let’s say you had 2 objects:
Case
Users
The relationship is as such:
Case [one2many] Users
You want your case record to have a list of users associated to it via a relation ticklist widget. You would configure your widget as you normally would, but you would also need to ensure the records in the Users object exist first, otherwise nothing will show within the ticklist widget.
Hope this helps
              Hello, did you find a solution to to allow users to select multiple options to a single question?
              Can you explain where the option is to set a Choice field (Tile Presenter) as multi-select as I cant see the option anywhere? Thanks
              Hi, I think this is only available if you are using a many-many relationship. I don’t think there is a way to store the multiple selection data if its a choice field you are using.
              I’m surprised there isn’t a presenter for a choice field for multi selection, It’s a basic form input function.
Are there no custom presenters that do something similar, I could at least use that as s starting point.
