Softphone Issues
We have just deployed the embedded softphone out to some of our teams. There does not seem to be an option for a supervisor to listen to live calls if both parties are using the softphone though. It only gives the supervisor an option of " call me at " which would be an extension or inputted number. Are there plans to make the option to monitor when the supervisor is using softphone too ? as we would like all staff to be using it going forward.
There also seems to be a considerable delay in calls terminating with the agent after the calls have finished
Hi Ian,
Thanks for your feedback on the use of new embedded softphones. Currently this feature can only be used as an endpoint for agent calls. However we do have a feature on our roadmap to enhance this so that supervisors wanting to monitor an agent call can also use the embedded softphone for this purpose. Unfortunately I am currently unable to provide a timescale when this will be available.
With regards to your other point where agents are experiencing a delay when a call is terminated, can you please log a ticket with our support team so that this can be investigated.
Jonathan Gunner
Good Morning,
Is it still the case that Supervisors cannot monitor calls via the SoftPhone?
Hi Paul, you can monitor an Agent who is using a Softphone, but this cannot be sent to the Supervisor who is using a softphone. The Supervisor must put in a number to call to monitor/assist.
One thing to note is that if the Supervisor received a call through the softphone, this would take up a license, which could cause a potential issue if the number of available Agent licences ran low. Ensuring this is sent to a physical number removes the need for a license.
Jonathan Redsell.
Thanks Jonathan,
Thought I couldn’t see it being available in the release notes but as you originally posted in 2021, wasn’t sure if I had missed it.
Hi - we are looking to use the Monitor call functionality. I see this topic of an Agent and Supervisor both being on softphone was addressed in 2023 - Our supervisors and agents will be using softphones going forward ( work from home etc) - has the issue of having to entered a number to be called on still being looked into?
Nicki Lennox
