Using fuzzy logic when searching data objects in Create
Does anyone know if there is a way of using fuzzy logic to search data objects in create?
Many Thanks
Hi @JonathanFS ,
By “searching data objects” I assume you mean data that is held within an object?
If so, In version 2024.2 we introduced the Advanced Search widget, which allows you to build a search-based widget with fuzzy logic to search and filter data. It’s really flexible in that it provides you with extensive options to tailor your search - Similar to how you’d define subset conditions - You can use comparators, filters and operators to search by.
Click here to see the 2024.2 releases notes
Click here to see information about widgets (including Advanced Search)
Hope this helps :slight_smile:
