Using 'use_blobs'
When opening a file with ‘use_blobs’ set (as documented here Help Portal), I am not clear what object is returned now how to process contents using it. The normal Node Buffer/Blob methods throw an internal error, and simple iteration doesn’t work either.
Here is an example of something I have tried
  main: function(record_id, parameters, rule) {
    const file = cs.read_file(record_id, params.custom_paths.file);
    cs.log(\[file\]); // \[binary data, length 87071299B\]
	const stream = file.stream(); // An internal error occurred
    let i = 0;
    for (const c of file) { // TypeError: Result of the Symbol.iterator method is not an object
        cs.log(c);          // this line is not reached
        if (i++ > 50) break;
If I remember correctly you can call toString() on the file object it should return you the file content.
Hey
“blobs” are basically a wrapper around strings, as Javascript strings are not suitable for binary data as they’re UTF16
But you treat blobs like strings - you can append them, concatenate them etc for the most part just as if they were regular strings without their encoding being converted. Many of the common JS String functions work.
You just have to be aware though that if you do use toString() to get at its contents for anything other than perhaps debugging, it’ll be UTF16 encoded and likely give you problems if you try and write the file back and it’s supposed to be a binary format (e.g. image, msg, pdf, etc).
If (based on your code) you’re just trying to log the first 50 characters of it, you can probably just do:
cs.log(file.substr(0, 50))
Hope that helps
Mark
Thanks for this.
I am actually using this to parse a very large csv file (causing OOM when not using use_blobs). The only way I was able to get this working as to immediately call toString(), which curiously did not give me OOM.
Do you have any further docs on what operations are supported (.length, subscript operator etc.)?
