Hi all
Is there a way to notify users of IE11 that the page will not display correctly/unsupported?
cheers
Hi all
cheers
IE 11 is a supported browser, and I know a number of bugs have been fixed that are specific to it. In the first instance, I would raise support calls for any issues - and only worry about a warning if the response is that they can’t be fixed!
That said, and regardless of the above, I think a simple Widget on the page could detect the browser and display a warning message if it finds an unsupported one.
I have put a widget together, which I will submit to the community, but it may take a while to appear, so PM me if you want a copy. I have used the bowser library to detect the details, rather than just looking at the Agent string.
