Weird regex problem in CS
Maybe I’m doing something wrong here but the following regex just will not validate as true - despite this being perfectly valid …
let my_string = “012345”; // included here for the avoidance of doubt - but it actually comes from a fragment_presenter.get_value() call
let regex = new RegExp(“^\d{6}$”);
cs.log(“Test Result: “ + regex.test(my_string));
please excuse any minor code transcription issues
It’s supposed to return true if my_string is exactly 6 characters in length. Works fine in every regex validator I can find but not in CS. Always comes back false.
Before anyone asks - yes my actual string is tested as being 6 digits long :grin:
This specifically is a fragment validator component.
Thoughts ?
Try:
let regex = new RegExp(/^\d{6}$/);
or
let regex = /^\d{6}$/;
More specifically:
main: function(fragment_presenter) {
    // const regEx = /^\d{6}$/;
    const regEx = new RegExp(/^\d{6}$/);
     // cs.log(regEx.test(fragment_presenter.get_value()));
    if (!regEx.test(fragment_presenter.get_value())) {
        return {
            valid: false,
            error: "Value must be 6 digits long."
    return true;
will check it out thanks.
Did you get this working?
To clarfy, I think the issue is your string is not properly escaped…
let regex = new RegExp("^\d{6}$");
would need to be
let regex = new RegExp("^\\d{6}$");
or, as Neil pointed out you can use slash notation instead of double quotes to avoid this…
Note, this is a native JS syntax thing, not specific to Code Studio.
