When is a Subset Recalculated
Can someone explain when a subset is recalculated, I thought that if the base object for a subset has been updated the subset recalculates.
Does the field being updated have to be used in the Subset for it to be recalculated or does the Subset recalculate if any field is updated.
Hi Jonathan,
So Currently, the selected priority affects how often the Subset should recalculate.
High - Recalculates every 5 minutes
Medium - Recalculates hourly
Low - Recalculates nightly (Between 2am and 3am)
Note that when you create a record used by a subset, the subset will be calculated instantly.
Warm Regards,
Neil.
