The great guys in the Netcall Training Team are pleased to announce that a new E-Learning course has been added to the myNetcall E-Learning Portal. This course is based on the Test Studio functionality found in V10.4 and above of the Liberty Create platform.
We first blogged about this here.
The Test Studio is a brand-new feature added to the Liberty Create solution enabling users to test their applications as they progress. It allows you to record and playback your tests, add assertions, slot new tests between others and more. This course will teach you how to use the Test Studio within your own instance of Liberty Create.
To access this course, head over to the Training section displayed at the top of the screen and click the Netcall eLearning option. This should then automatically log you in to the myNetcall eLearning portal, from where you can select the Catalogue option displayed in the top left hand corner of the screen. Once in the catalogue, use the Search option at the top of the page to search for the Liberty Create – Test Studio course. Clicking Enrol will add the course to your profile and allow you to view it. The course is approximately 50 minutes long. If you don’t complete the course in one sitting, you can exit and return to wherever you left off at a later date.
If you have any problems accessing the myNetcall Portal or the course drop the team a line at training@netcall.com and they’’ll be happy to help.
Cheers, Tony
